so, proof of concept is the first order of business. now I have read a lot of folks methodologies on this and some boys get real techie! with their mechanical and chemical degrees and such. I on the other hand have taken the construction engineers approach and decided to go for the make do method.
I have 1ltr of this coming in tomorrow....
for those unfamiliar with the product, im sure you have seen pressure gauges at some point with the scale and needle. these are generally glycerol filled but in the oil and gas industry we are moving towards a silicon based filler as above, highly unreactive, viscosity of water, dialectical low and relatively cheap at $60 per half litre (im estimating on a fair bit of wastage as the watch will need to be submerged for my "no bubble" concept). most methods show a vacuum pump and an expansion system, normally a bit of non absorbent foam or high density something or other. if you look at the expansion % of this liquid I personally think I will not need to worry about it as the temperature range is so vast but we shall see.
so I have the oil on order and will be here tomorrow. the vacuum pump bothered me, $500 for a system just to fill a $400 watch! nah, I have a storage vacuum bag and a hoover
basic principles are as below and I will update with pics and full narrative for anyone else who fancies a bit of stoopidity :thumbup:
1. strip watch to case and movement
2. remove movement
3. place case in bowl of liquid
4. place bowl in vacuum bag
5. vacuum to remove all air from case
6. open and install movement while still submerged in bowl
7. revacuum with movement in place
8. open bag and finger fit case back while submerged
9. remove and screw case back tight
after the above is done, ill test in the freezer for 24hrs and then in 50-60 deg water bath to ensure expansion factors are correct and no air or vacuum bubble is present (a common mistake for people with UX bubbles is they think its air, its actually the opposite, its a vacuum where the oil has contracted in the cold and left a vacuum bubble, hence why it disappears when it warms up)
all going well I wil have pics of the first attempt tomorrow :D watch this space.
