Common coin / button battery conversion table
  • Common coin / button battery conversion table
    Good conversion table for many of the common standard coin / button watch batteries / cells:
    Click image for larger version  Name:	watch.battery.conversion.png Views:	1 Size:	709.4 KB ID:	43147
    Purely FWIW, if possible we install genuine Made in Japan SEIKO cells, in our (albeit very limited) experience genuine Made in Japan SEIKO cells do not leak, even when they're left dead in watch cases many many years they've not leaked in our experience... a dead cell will over time may burst & leak its acid etc all over the quartz movement destroying parts like circuit boards and so on, which isn't desirable.
    Also, often, genuine Made in Japan SEIKO cells seem to also exhibit useful model names, i.e.:
    616 = 1.6mm thick
    626 = 2.6mm thick
    927 = 2.7mm thick
    731 = 3.1mm thick & so on...
    Harlan
    Timekeeper Watch Club
    Auckland, New Zealand, Pacific Ocean, Earth
    Fantastic H
    Can we make this a sticky somewhere?
